I flushed my transmission, changed out the filters, added a Suncoast deep pan internal filter clamp from Kennedy, and went with the AMSOIL Synthetic Universal Automatic Transmission Fluid (not Torque-Drive) product at about 1000miles. My choice of UATF was based upon comparing the fluid specifications, the advice of the AMSOIL factory at that time, and this write up from AMSOIL, which in summary says…
“AMSOIL ATF is a more advanced product with universal applications such as Mercon V and ATF +4. AMSOIL does not recommend draining or switching to Torque-Drive™ unless the Allison customer intends on following the extended drain interval recommendations of Allison”.
The whole note about TranSynd and the TES-295 specification is worth the read.
AMSOIL Torque-Driveâ„¢ Q&A
10,000 miles or so of Texas heat, off road dust, some towing, and one external filter change later everything seems solid and looks clean but I am planning to drain the transmission, drop the pan, and have a look see.
I recently received a bulletin from AMSOIL about their new Low-Viscosity Automatic Transmission Fluid. I called the AMSOIL factory rep to ask about it before ordering a case of UATF. He told me that the new Low-Viscosity Fluid product is the ONLY transmission fluid that AMSOIL now recommends for the Allison and indeed, if you use the AMSOIL web site product guide, this is the only transmission fluid you will see listed for 07 and up GMC/CHEVY Diesel (Not UATF or Torque-Drive).
I asked the AMSOIL factory tech for the data to support the use of this product with an Allison and I was told that they do not have anything ready for publication yet but that it is, supposedly, coming soon. I also asked about compatibility with their old UAFT and the new Low-Viscosity ATF and was told “no problem”.
Before I take the plunge and switch products (which I hate to do) I was wondering if anyone here has any real (not antidotal) data about this new product and the reason for the sudden, and seemingly quiet, switch to it by AMSOIL. I asked the AMSOIL tech rep that question directly and, while he was certainly very cordial and generous with his time, I felt like I was getting more of a marketing pitch than any real data.
I have been a happy AMSOIL customer for 20 years and their track record with me has been impeccable but the way this one is being rolled out just seems a bit odd.
