21 - 40 of 327 Posts
Discussion starter · #23 ·
Take a picture of the of the spliced wires. I don't understand how a dog rips greasy wiring harnesses from on top of the engine bay.
What started as a problem with some mouse chewed wires under the hood and a bad taillight and turn signal has turned into a bad Body Control Module that still didn't fix my original issue of the taillight and turn signal. Fuses all checked out. Next step is all the wiring, bumper to bumper. Could I possibly get the complete schematic for a 2013 Chevy Silverado 2500HD 6.0?
Discussion starter · #26 ·
Complete diagram? No, sorry. But if you have anything specific I'll try my best.
Discussion starter · #27 ·
Looking for a complete fuse box wiring diagram for an 02 and 04.5 2500 had ext cab.
Swapped cabs and need to know what wires and connectors to swap properly.
[/QUOT
No problem. I have the diagram pulled up now, but will wait, since it's a bit late at night and stuff needs to get done early morning.
I just bought ProDemand, if you guys need anything let me know. I have the shop version, so 2001 to 2021 trucks just be specific on what you need.
I could really use the TCM pin #s or the TCM wiring diagram for a 2004 LLY At the TCM & at the plug on the back of the transmission . trying to figure out an E shift silinoid electrical open circuit. Any help would be appreciated. Thank you.
It would be great if we could get some information on an lbz 2006 sierra from the bail connector to the controller. I have replaced the wire harness and all the injectors and can't clear the 0201 0204 codes I know they are tied together on the engine harness which is brand new. We swapped injectors and repeat the issue so we have eliminated the possibility of a bad injector. Now we are about tobchase this common wire down on the truckbside of the small bail connector. Thanks in advance.
Im having a problem with a 2006 2500 6.6 duramax. Window and door controls dont work , checked harness going through the pillar are good,need a schematic to find where it is all controlled . If you could help. has a new switch cluster also thanks
@PowerHusler think you could get me the wiring diagram for the power folding mirror switch for 2012 GMC/Chev trucks that year that had the option? Any help is much appreciated.
hey there, im new to The forum.seen your post about diagrams and schematics and I was wondering if you could get the wiring schematics for a 2013 Chevy Silverado 2500 HD LTZ I need everything for a basement clusters the radio the nav systems the engine controls, the lights, pretty much the whole spiel if you got it. three-four mechanics on the truck tore up everything and mangled several wiring harnesses.
thank you appreciate this
respectfully,
Jeremy
I have a 2021 Silverado 1500 with 3.0 Duramax
I’m trying to add a set of factory power assist steps
(I think that’s what they call them) Running boards
My truck didn’t come with them and I’m trying to find the connection points I need to tie into to make them work. Do you have the ability to see the diagrams for this?
Also I have a VIN of the truck they came off of that did include the wiring if that helps in any way.
From what I’m finding trucks that came with the steps have a chassis harness labeled as option BRS with code of J305
man I would greatly appreciate any help you could offer!!
