Just finished installing the Banks Ram Air intake, with the optional Super Scoop on my 2011 LML...
The air intake was easy, everything went together and installed nicely. Where I seemed to have a bit of trouble was with Super Scoop install...
I read and followed the install instructions to the letter, tho there seemed to be some steps for the 2500HD that I didn't need to do, mainly with removing the splash guard with the wheel liner, and cutting the wheel liner with the splash guard per the instructions.
When I removed my wheel liner, the scoop fit nicely to the air intake housing, and ran down the metal bar where the lighting harness and horn are located... so I mounted the scoop along this point, which is as far forward it will go and still be aligned with the bottom of air intake housing...
My question is when I had my after market bumper installed, would some of the parts been removed and not reinstalled? Also here are some pictures, things seemed to fit okay but I had to cut the mounting brackets for things to fit right. No real difficulties, just concerns that I may not have installed the scoop correctly, thoughts... feedback...
As anyone had the same or similar experience???
I plan to plastic dip spay the brackets, but not until after I know I'm keeping the scoop on for good, or at least awhile...
