I'm planning some upgrades to my truck for the future addition of a truck camper. Dry weight of this camper will be around 2,500 lbs.
I've got an 07 Classic 2500HD. From my understanding, the 1-ton version of my truck had 1 additional rear spring and 1/2" wider steel wheels.
I've already added wheels with a 4,500 lbs rating and tires with a 4,080 lbs rating.
I will be adding a Hellwig Big Wig sway bar to help with sway stability.
As for the springs...
The factory springs for the 2500HD are quite soft which is nice for unloaded daily driving.
I'm looking at Sumo Springs to replace my factory 3 1/2" tall bump stops which currently have a 4" gap before bottoming out on the axle. The Sumo's hang down around 6 1/4".
Without upgrading the springs, I feel the heavy load would just sit on the Sumo "bump stops" at this point.
My question is, is there an additional spring package like the SuperSprings, Hellwig Helper Springs, Deaver Mini pack, etc...that will help carry the load/keep me level but also not put me in a "stink bug position" when the camper isn't on the truck?
My hope is to avoid air bags, while the adjustability is nice, I don't want a leaky bag or failure while out on the road.
Any help is much appreciated!
