Hey guys im looking to install a 0-30 fuel pressure gauge in my supply line coming from the filter houseing to the FICM.i was planning on splicing the line and putting the sender in there. however..i Need to know what pressures the Cp3 tends to pull from the tank because if its around 5 psi then it wont make much sense to put the gauge in....i kinda thought that i can monitor the pressure in between filter changes and when it starts to get lower ill know about how often my truck likes to run on a filter and i will get a lift pump eventually also...so Does ANYONE know about how much pressure the CP3 pulls from the tank? NOT the pressure it pushes to the rail. Thanks:drink
