The stock 2023 4x4 cab and chassis 5500 Silverado comes detuned to 700 pound feet of torque for emissions? What is required to match the 2500/3500 power ratings?
I am curious since you like the DEF on the right, what is your reasoning for that? I use truck stops to fuel up and it is a PAIN to reach the hose to the passenger side for me.Personally, I like the def on the right. Never heard of someone putting diesel in the def tank or vice-versa until GM put them both on the same side. On the MD it is right out in the open.
Better check on the air ride for your truck- when I got mine , 4x4 got everybody a 7500# front axle but no air ride with 4x4 available.
Also, these trucks are speed limited based on what gearset you have.
I don't think GM has ever published the exact differences between the L5P and the L5D beyond the turbo and ECM. It MIGHT has some internal changes as well.
GOOD POST!View attachment 1114126
Here's another forum you could join with some info.
L5P: - L5D convert to L5P?
So how hard is it going to be to make an l5d in the new medium duty produce the same power as an l5p? I assume the turbos will need swapped and a tune. Would one be able to flash a tune from say, a 3500 regular truck onto a 45/55/6500 computer?www.dieselplace.com
The complication you will have is dealing with a tune and a locked ecm. I wonder if a conversation with Banks and trying a couple less expensive less evasive products like the peddle monster and or derringer would not be a great place to start.
Made for some fun research. Seem the only engine difference is the undersized turbo which must be replaced before trying to increase hp/torque, engine tuning and of course the rest of the drive train.
Personally if I was wanting to throw money at it I'd start with a conversation with Banks.
