How To: EGR block off in LMM !!
238K views 405 replies 117 participants last post by  Eagleye88
Ok...after much swearing and general deliberation I think I've come up with an easy system to install an EGR block off plate in a 07.5-09 LMM. You will need :
Moving blanket or other thick blanket
2 Stubby flat blade screw drivers..I like the craftsman ones
1 12mm ratcheting wrench
1 14mm stubby open end wrench
Tin snips/hack saw/band saw
First thing to start with is removing the intake elbow from the filter box and the turbo inlet tube and set it aside. Then remove the silencer (large plastic box with the 6.6 on it) it's clamped on the underside to the turbo inlet tube and fastened in the front by a torx fastener. Now, lay the blanket over the air box and the engine bay on the passenger side up to the turbo inlet....this makes working back there ten times better. The EGR pieces you're looking for are located almost at the firewall on the passenger side of the compartment. Remove the small sensor that is screwed into the engine side of the EGR piece and move it out of the way...this will take a 14mm open end wrench. You now have as much access as you're going to get and this is where the 12mm ratcheting wrench will be your best friend. Loosen the 2 12mm nuts holding the EGR mating surfaces together...they face the firewall and are offset from one and other passenger side lower than the driver side. THEY ARE VERY TIGHT !!! You may need to link another box end wrench on your ratcheting wrench to get enough leverage to get them off...be persistent. Now the fun part...with both nuts fully removed wedge one stubby screwdriver at the top of the mating surface and pry like your life depends on it...mine was exceptionally tight. (Make sure the gasket is on the firewall side mating surface) Once you have the parts separated take the other screwdriver and wedge it in on the outside of the driver side bolt sideways. Keep working the two screwdrivers until you can get the sideways screwdriver pushed in almost almost all the way down the blade...trust me it will stay in place. Take the EGR block off plate you purchase from your retailer...I used the one from Meyer performance...and snip the ears off the far side of each plate. It should wind up looking like it's got a hook on either side where the stud will locate it...I trimmed mine like this so you can leave the screwdriver in place while you drop the plate it. Wiggle the plate into position...at this point my plate just about fell into place. Reassemble everything in reverse...don't forget that little sensor you just removed...and you should be EGR deleted. My first attempt at installing the plate took me forever...I just did a buddies truck and it took me 20 minutes start to finish...GOOD LUCK !!!!
:drink
#37 ·
I basically messed around for an hour trying to get the nuts off, linking wrenches together and all sorts of crap. In the end the only thing that worked was just about standing in the engine bay and "snapping" the bolts loose. Give it everything you got in one quick motion straight up standing over the motor. I never thought I would get them free. You just have to get the bolt to pop once then its butter.
#38 ·
I got tires of messing around with wrenches and not getting it. I just got back from sears with a 11.5 inch long 3/8 inch drive flex head ratchet, a 16.5 inch long 1/2 inch drive flex head ratchet, and a universal joint for a 1/2 inch drive ratchet. Hopefully I'll get those nuts off tomorrow somehow between all of that and my breaker bar.
#39 ·
I finally got my EGR blocked!!! What a PITA. The 11.5 inch long 3/8 flex head ratchet did the trick. Thank you all for your advice. I'm definitely glad that I don't have to do this again.
#41 ·
This one wouldn't have taken long if those nuts weren't so stubborn.
#42 ·
Now I have a high pitch whistle / shreiking noise when I am on the throttle at all. Of course it didn't make any noise sitting at idle this morning when I would have had time to play around with it, it waits until I get on the road on my way to work and starts. I am guessing that it either isn't tight enough or the gasket is pinched at the bottom. The bottom was really tight when I got it in there. I guess I'll be back in there messing with this again tomorrow. Are you guys sure this thing is worth the trouble?
#44 ·
HAHAHA.....mine did the same thing first go round. The plate probably seems like it's all the way down in position but it's not......pry the two pieces apart more and you should be good.
#43 ·
Its well worth it if you dont want soot going into your motor, the pictures of the intake are worth a thousand words
Not sure why it would make the noise but make sure the gasket is on the firewall side
loosen it back up make sure everything is tucked in there right and tighten those suckers tight.............I'm telling you stuff you all ready know but just making sure
#45 ·
Todd, you were right I hope. I got the bottom part to go down a little more, revved it sitting in my drive way and no noise. I'm keeping my fingers crossed, tired of messing with this thing. I'm off to check on my ponds and maybe do a little fishing, so I'll see how it does on this little trip.
#46 ·
All looks well, finally!!
#47 · (Edited)
THe Duramax uses coolant to cool the exhaust before going in the air intake. This raises coolant temps. Not to mention, it degrades the incoming air for a cooler, but less effective ignition burn. EGR block-off translayes to more power, less heat, better fuel mileage.
#49 ·
Well, it's whistling a little again. I'm working days this week and won't have time to play around with it until Friday morning. Will it hurt anything to drive with a small leak?
#50 ·
Shouldn't.....be mindful though of stopping anywhere to long....raw exhaust being caught against the firewall might seep into the passenger compartment over time.
#51 ·
I think I finally got this thing fully in yesterday. I couldn't wait until Friday. The bottom part of the flange on mine just didn't want to separate. I finally pried it from beneath enough and the plate fell in further.
Now I am paranoid every time I take off and start to hear a little whistle, but it's just my turbo spooling up so far.
#52 ·
yeah im new too and wondering the same ? whats to gain by doing this, is it worth the time?
#53 ·
Just finnished putting mine in about an hour ago. It took me about three hours and every thing was still hot so it made it even harder but overall it really wasn't that bad. I also used a 3/8 drive flex head ratchet about 12" long and a shallow socket to break the nuts loose then a stubby wrench to finish. For the Bottom bolt I went from the wheel well. To seperate the flanges first I tried a pry bar and that got it a little bit but it wasn't enough so I used a tire iron to pry them apart and the blocker fell right into place. Now I am trying to decide what to do next but I think I am running out off cheap tricks so the next mod might take a while.
#55 ·
seen some pictures of the build-up and it looks pretty nasty. mine has 60 k on it and im gonna do this mod, but i was wondering is there a way to clean the whole system. ive heard bg products is a good way but also read about using water while engine is running to break it loose??? does that sound right. Ive done this on gas burners to clean piston tops and valves but not sure about on a diesel. what to do?
#57 ·
is that a kit, or an add on or something? obviously i cant put water in the fuel tank... so is this an inexpensive fix?
#59 ·
Not really.....I was referring to a water methanol injection system used primarily for lowering EGTs. As a byproduct though it cleans the inlet piping quite well......but $500 and up for the kit isn't inexpensive.
Honestly....your best bet is removal of the upper intake pipe and a little elbow grease and carb cleaner.
#60 ·
It's a multi-layer metal gasket so yes you probably just caught a glimpse of the gasket. I don't think anyone has a good pic of the EGR plate......it's just to hard to get a camera back by the firewall to get the picture.
#64 ·
wel, i tried to do the egr plate today and for the life of me, i could not get those damn nut loose, i tried for probably 45 minutes and could not break them loose! i was using a 7-8 inch gearwrench ratchet wrench and just couldnt do it. i never tried the bottom nut bc i couldnt get the rea one loose. i was so pi$$ed and still am. i am going to call jeff dean tommorow to see if he has ne pointers or how much to do it.
#67 ·
I CALLED MY FRIEND HE IS A GREAT MECH 6'5 265lbs works out daily took him about 15 min wanted to give him 50.00 would'nt take it!
#68 ·
My buddy was a lot smaller and just laid uo there. He had done a couple. Cost a whole beer.:drink
#69 ·
nice job ..man
#70 ·
Thanks.....after my frustration the first time through I thought this would help everyone steer clear of my pitfalls. Glad this keeps helping everyone :drink
#71 ·
Anyone have pics of what it should look like and where are the 2 egr cooler screws?? sorry dumb question but im sure someone else wants to know and dosen't want to ask.
#72 ·
Actually I have the EGR removed now so I can get some "off the truck" pics of the whole arrangement if you like. I'll see if I can get something posted in a little while.
#73 ·
ive read how to do this 100 times and Im still going out looking in my engine bay at the egr:blowup thinking.. this is going to be INSANE. Im gonna do it anyway, while im at it im gonna install my mbrp downpipe and do the pcv reroute.. 10000 miles to late but better late thenneve.
