ok well here's some news... the light bulbs that illuminate the gauges are soldered into the entire circuit board. they are not a "pop in, pop out" replacement. maybe on earlier models, but my 05 LLY has them soldered in, and in an almost impossible way to replace. I took one off and went to Radio Shack and they have a close replacement, just a little smaller.
272-1029 - i soldered a new bulb on and it works fine. in case you have never removed your gauges, it also is a pretty complicated, time consuming process. The needles have to come off all the pins, and the face will come off, exposing the light bulbs. i actually had 2 of them burnt out, so i'm sure there are plenty more to come. YET ANOTHER excellent design from our friends at GM. has anyone else done this procedure? i took some pics, and can upload if need be.
