Fuel leak on 2004 GMC LB7 Duramax diesel passenger side. Replaced the fuel filter. Pump filter housing & WIF sensor and both fuel lines from the pump filter housing to the EDU. Still leaking fuel under full throttle above 65 or under a load while pulling my fifth wheel up any hill. I have fuel all over the battery and fuel pump on passenger rear side of the motor.
I usually am able to figure out my problems. Truck has 230,000 miles on it and the injectors were replaced around 160,000 miles. Any help would be appreciated.
