I think they may require you tighten to X, do a little dance, pray to the gods of suspension, then crank the nut an additional X degrees. But, perhaps not with the 3500. I don't know. It's crazy this info isn't readily available.
I have (had) the rear clunk when stopping (not always). There are a bunch of posts on that out there. Noticeably worse this cross-country trip. I guessed it might be the u-bolts. After breaking initial resistance, I could get a little movement with 70#. I worked the pattern in stages and went to 100. Clunk seems to be gone. Since I can't come up with the definitive answer, I'm going to go with 118. 2,600 miles to get home with our camper in tow, so hopefully this works.
I'm still hoping someone on here has the correct answer. Pulling out at 4AM. Thanks.
