This is how I did my factory air box mod. There was no sawing, grinding or any pop rivets to put in. Does it breath better??? I think so. Check out the pics you be the judge. All you need is a good razor knife and a small pair of flat nose pliers.
Here is the box with the lid off ready for mod.
First you need to remove the intake cover that pulls air from the passenger side fender front fender.
Simply pop loose the little tabs on the top and bottom of the air box.
Here is where you should be so far.
Now just take your razor knife and score the outer edges of the "fan blades".
