Loud whine/hum at high RPM?
8.9K views 9 replies 8 participants last post by  Thopper196
Hey all,
So when downshifting on a steep hill usually towing the tow/haul feature shifts down, and RPM's jump up I hear a loud whining noise, until the RPM's lower. Sounds to me like the fan clutch, or bearing? Any ideas or experience with this? Thanks!
Reactions: Jeremy Ingram
What do your fluid levels look like? Trans, TCase, diff... That would be where I'd start but its hard to diagnose things without more info or hearing it in person.
Sent from my iPhone using AutoGuide.com Free App
Is the truck up to normal temp? My 06 lbz whines like a baby when it's cold. I hate it. I've gone over everything and I think it's one of my idler pulleys.
Sent from my iPhone using AutoGuide.com App
#7 ·
Mine did as well when it would drop below freezing. It quited down significantly after I flushed 5 quarts of new fluid through the hydro-boost.
Fluids are all good. It's always around operating temperature when it happens. 90% of the time, starting, warm up and day to day driving it sounds great. It's just when down shifting and getting the RPM's approx. over 3K. My best guess is the fan clutch or bearing? Just thought I'd see if anyone has had the same issue... Thanks
You didnt leave it in 4wd on accident or something did you?
