Hey Guys,
Bear with me, I want to give a bit of back story on this issue. I bought an 03 recently that I've been doing a bunch of work to, and after an issue with the truck burning some coolant, and getting coolant in the cylinders every now and then, I narrowed it down to injector cups, or head gasket. So I decided to replace the injector cups. When I took off the valve cover, I found the that the entire top of the cylinder head was covered in a 1/4" to a 1/2" of thick slimy sludge. And seeing as I was in a hurry, I cleaned everything I could get to, installed new cups, and reassembled. And after all of that, I'm still dealing with coolant consumption and a slight hydro lock once and a while. So I decided to do head gaskets... I ordered a full kit with ARP studs from Lincoln Diesel Specialties as well as a few other parts - manifolds, up pipes, down pipe, water pump, rebuilt turbo, and a whole lower end bearing kit to freshen up the motor. So I'm going to pull the motor on Friday next week and I really want to get all of that sludge out of there before I reassemble. I may get flamed for this, but I was thinking of using seafoam in the oil this week to break all of that up so it comes out when I drain the oil.. I'm prepared to hand clean a bunch of parts still, but I would like to get the bulk of this stuff broken up..
Does anyone have advice on how to loosen all of this junk up?
Thanks in advance!
Thanks in advance!
