NOx sensor part numbers
1 reading
24K views 3 replies 2 participants last post by  SRQDenali
#1 · (Edited)
To everyone frustrated with the availability and mystery of replacement NOx sensors:
I'm posting this to, hopefully, help with sorting out the array of part numbers for the 2015/2016 LMLs. I think this information will also work for most any model year LML if it contains one of these part numbers. Here are compatible numbers that cannot be cross-referenced anywhere that I know of. Even my local GM dealer couldn't look-up or cross reference these numbers.
Upstream Position #1 GM part numbers:
GM 19301328 (superceded, but possibly available as NOS)
GM 19302359 (GM shows this as the only replacement for 2015/16 models, NOT TRUE! This is unlikely to match your original part #, since it is a replacement for a superceded part)
GM 12662971 (if you order 19302359, this is what they send you)
GM 12648630 (this was the original part on my 2015, but no longer available)
Downstream Position #2 GM part numbers:
GM 19301329 (superceded, but possibly available as NOS)
GM 19302360 (GM shows this as the replacement for 19301329 for 2015/16 models. This is unlikely to match your original part #, since it is a replacement for a superceded part)
GM 12648631 (what my 2015 came with)
GM 12662972 (what I'm running now)
DISCLAIMER: I cannot say with 100% certainty which part number will work on every model. There are mid year variations and other part numbers out there that I have not verified. I suggest that you first check to see what part is on your LML truck (regardless of year). If your original part number is listed above, then any of the part numbers that I listed should work, so long as it is in the same position (upstream and downstream sensors are not interchangeable). IF your truck has a different part number, do some research before using any of the numbers above. Ebay has good prices on some of the above numbers. I tried to stick with GM or AC Delco parts rather than the Chinese-made ones. However, they are probably the same parts. If you pay more than $250 for a NOx sensor, you paid too much. Most of these should be between $160-250. A GM dealer will rip you off for more than $500.
NOTE: If you swap the NOx sensor yourself, it is pretty easy (unless the sensor is seized in the bung). The upstream sensor is at the rear of the engine downpipe and the controller is on the firewall (driver-side). The downstream sensor is on the top of the SCR/DPF and is much harder to access because of the driveshaft. I dropped the driveshaft, which made it much easier. After replacing the sensor you can take a scanner and clear the fault codes. If you were getting reduced speed warnings on the DIC (limp-mode), those warning will usually clear themselves after 50 miles and an overnight cool-down restart cycle (sometimes more than one cycle). If not, there may be other issues (DEF injector, DEF quality, heater, etc), If so, the fault codes will return. If you originally had several fault codes and one of those was a NOx fault code, I'd suggest starting with replacing the NOx sensor first. That may be the only issue and could be causing the other codes.
owns 2015 GMC Sierra Denali
Reactions: CSC5150
As mentioned in my Note above, the 2015/16 models the position #1 sensor is located at the rear of the engine on the exhaust near the firewall. The controller is on the firewall near the brake master cylinder. It's about 2.5" square and has a small wire harness. Once you located the controller, just follow the wire to the rear of the engine and you'll see the bung with the sensor.threaded into it. Its fairly easy to access and remove if you have a sensor removal tool and the threads aren't seized. The position #2 sensor is located on the top-center of SCR/DPF (that's the larger of the two "muffler-looking" chambers on the exhaust system. It is the larger of the two sensors. The other one is an EGT sensor, I believe. You can get both on eBay for around $300 + tax. I used 12662971 and 12662972 and they can be purchased together for that price. Factory GM Duramax Diesel 6.6L NOX Sensors Set Pair 12662971 12662972 | eBay
If you can swing it, I would just replace both. The position #2 sensor is must harder to get at. I ended up dropping the driveshaft which is really quite easy (don't let the u-joint caps fall off or you'll lose the needle bearings). That one is usually harder to get out because the threads are burned and sooted-up. The removal tools sometime come with a thread chaser. Or you can us a thread tap to clean up the bung hole threads after removal. Some recommend soaking the threads in PB Blaster a few times in the days preceeding the removal. I didn't find that to help very much. I just had to use a 20" pull handle to have enough leverage to muscle it out.
#4 ·
FYI, Ebay has the pair of GM NOx sensors right now for $273
For GM 12642310 & 126542311 SET Nitrogen Oxide NOx Sensor For 2011-2015
12642310 Upstream Nitrogen Oxide NOx Sensor For 2011-2015 GM Duramax Diesel 6.6L
12642311 Downstream Nitrogen Oxide Nox Sensor For 2011-2015 GM Duramax Diesel 6.6L
Package You Will Receive: 2PCS NOx (Nitrogen Oxide) Sensor
Part Numbers: 12642310 & 126542311
Vehicle Fitment:
Fits for 2011-2015 Duramax Diesel 6.6L
2 Pieces 12642310 & 12642311 for GM 2011-2015 Duramax Diesel 6.6L NOX Sensors | eBay
These are unbranded/ I've been runnin the unbranded ones for a couple of months on my 2015 with no issues. Like I said before, I believe they are all made in the place and sold to distributors that can either resell them branded or unbranded.
