I have a 2016 3500 HD Silverado. I have this message counting down to limp mode.
I have had an issue with Coolant bypass valve for about 6 months and it throws a code but never had this message of death.
I had a diesel leak at the fuel filter which caused my truck not to start. It just required tightening of the filter. Primed it up and started the engine with the air intake pipe still disconnected. (Not good!)
It threw a code for the MAF sensor ( due to the pipe still off ) and this message has been there ever since.
I tried clearing the codes but he message remains. I tried driving for a while hoping it would reset itself. I tried disconnecting the batteries overnight. Had battery cables +/- connected together while disconnected. I tried everything I could to get rid of this message that would soon render my truck useless!
I took it into a dealer to clear codes. There was still a code for the bypass Valve. They cleared all DTC'S and still the message remains.
The truck requires a test ( minimum half hour to run ). The truck needs to pass this test in order for it to allow the message to disappear.
Truck is at the dealer now. I am waiting for results.....I will keep you posted.
