Stuck Oil Pan Drain Plug
14K views 26 replies 22 participants last post by  Hate2looz
Got things together to change oil this past weekend. Once got up ramps and crawled underneath tried to break loose the oil drain plug. Would not budge with an open ended wrench. Tried with a 6 point socket and same but this time felt that might be rounding the nut so stopped. Any suggestions on how to get this plug loose? Called dealer and was told that if could not get it loose then would have to replace the oil pan. Ouch!!!! This is the third time that the oil was going to be changed. The first was at dealer with no charge. Did the second on own and just snugged up the plug when reinstalled it. If can get the plug out will not reinstall the factory plug but replace it with a quick drain plug from Femco. Before this had a Ram 2500 with the Cummins and installed this and had no problems with oil changes. If have to change the oil pan, any ballpark idea on price?
Based on the size of your oil drain plug, not all sockets are the same exact actual size. So if you have another socket, preferably a 1/2" drive, try that. Leverage is king so add something to extend your handle. Make sure you are on the plug absolutely straight. Pull evenly. Eventually, it will turn. If not, you need a longer handle.
There are sockets that are supposed to put the turning pressure a little away from the actual points of a socket and that saves the edge of the bolt/plug. They are expensive, but not nearly as much as an oil pan.
I have an L5P. But could be same drain plug? I had one that I guess I tightened a little too much but the bolt was very weak. I used my Knipex pliers (the best if you don’t have any) and they worked great. Then I replaced with a magnetic aftermarket PPE plug. I think it was like $20. I’ve changed oil on trucks and equipment probably a few hundred times in my life. I can say I probably did overtighten some but the plug must be of soft steel for the threads to grab and to be rounded so easily. No problems with PPE stainless as of yet.
Tough angle to try to get it on the bolt but 50/50 acetone/ATF is the best break free I've used.
As mentioned earlier, I'd get the oil up to operating temp to get some good heat into bolt and then try to loosen it.
#21 ·
They are from Snap on, its called Flank drive. Doesnt touch the corners. They were the first with this, but its been copied, i wouyld look for a cheaper version. I have the snap on for over 25 years, never strip anything, nver rounds off.
With a new bolt you should be fine. Always put a little oil on the rubber backside so it slides to torque. I have had them get stuck going on dry. You will always be consious not to over torque, trust me! be well
#22 ·
Not sure what you used / already have, but 6 point vs 12 point socket is a good idea where there is concern about stripping.
And is it metric or inch? (can you tell I haven't done an at home change on mine yet?)
Sometimes using a 'will fit' can create problems. Especially if it is 12 point.
6 point doesn't give as many easy 'fit it on' options if using a johnson bar, but with todays ratchets with the smaller angle between click this shouldn't be a problem.
