Update:
I want to update my original post concerning 2024 Duramax 3500 Denali Crew Cab long wheel bed. This is an issue with GMC 2024 and 2025 HD models. The issue is the truck disconnecting my 17,000 lb 39ft 5th wheel's (DRV Mobile Suites) when you are traveling on the road. This appears to be a common problem with any trailer that has a power source i.e. battery, solar. The brakes are electric over hydraulic made by Hydrastar. After 3 months of going back and forth with GM, installing the recall fix for this problem which did not work. I met with engineer from GM, GM regional Service Mgr., dealership Shop foremen and Service Director at my dealership.
This meeting finally came up with a solution. A part that can be purchased from Hydrastar for $50.00 (part #381-7074). I spoke with the Hydrastars owner and chief electrical engineer, Wendell, for 45 minutes. He pulled no punches and is very frustrated with GM after dealing with them over this issue. One issue is the replacement part for the GM recall is not going to work. I had the recalled part installed so I can verify it is not going to work. Five miles down the road trailer brake disconnect warning light came on. Put the 5th wheel back in storage and back to the dealership and then replaced the wiring harness for the 7-pin outlet in the bed and it did not work.
Hydrastar is very confident this part will fix the problem. After splicing this part on to Hydrastar’s brake wiring, I took the trailer out for over 25 miles without the trailer brakes disconnecting We are going to increase our milage gradually since we have been burned 4 different times with this dangerous issue. It appears that GM is not accepting any responsibility over this issue.
What bothers me is that GM is aware of this problem, and it appears that GM is trying to blame everyone else but GM. If it wasn’t such a Dangerous issue I would not be so concerned. I have had an issue with my brand new 2020 which is the exact truck configuration as this 2024. I traded in a 2017 GMC Duramax with the same configuration (never any problem with 2017) and first time we went to leave with 5th wheel and the new 2020 GMC Duramax 3500 it was not compatible with lights and brakes. Two 1/2 months later and again having to get GM engineer down to TX, he brings an LED electrical adapter with him made by Curt part# 57003 which lets truck recognize trailer LED lights. GM was aware of this problem but ran us around for over 2 months and we could not use the 5th wheel.
I have had it with GM. I don’t say this lightly, but I will never buy another GM product again and I have never had anything but GM products all my life. Just in the last 7 years I bought 4 GMC vehicles.. I know no truck is perfect, but these problems are too dangerous to ignore
