BG Fuel System Cleaning
2.9K views 10 replies 7 participants last post by  ManyTrees
I have 40K miles on my 2019 GMC Sierra HD Duramax and the dealer is recommending that I have the fuel system serviced utilizing the BG fuel system cleaning system. The price quoted is $400 and the recommendation is based on the mileage on the truck. I utilize the Archoil fuel system additive on a regular basis and don't have any issues with the vehicle. Jusy wondering if anyone has utilized the BG fuel cleaning service and how did it work. I only use the truck when I pull my RV trailer that is at approx 8K pounds. not a heavy load but a load just the same. I avg approx 10.5 mpg when towing at 75 mph and drops to 9.5 mpg when towing at 81 mph. usually avg 20mpg when running without the trailer. I live in Colorado at 6,700 ft in elevation and usually tow the Trailer up to the high country around the 10K mile elevation.
You've never had to do injectors on your lbz or lmm? My last lmm I had to around 180k cause the return rates went to shit and drained my rails when it was hot out and I was pulling grades. I see your sig has 2 pretty high mile trucks, it's impressive you've never had to do injectors on either.
I occasionally use BG Fuel system cleaner (for gasoline engines) in my Mercedes, maybe once a year or so. Good products. For the truck, I use Pri-D Complete Diesel Treatment. A 16 oz bottle lasts about 4 years because I use it after my truck is stored for 5 months.
I have 40K miles on my 2019 GMC Sierra HD Duramax and don't have any issues with the vehicle.
Then whatever the BG thing is going to do, will be for naught.
If it makes you feel better, toss in a bottle of whatever cleaner / treatment catches your eye..... like Stanadyne.
Your out $40.... max. This will treat 10 fill ups.
As everyone else has said, it sounds like they're trying to make a buck off you. I don't have an l5p, but have known plenty of people with varying years of duramax and I've never heard of a dealer recommending a fuel system cleaning. If you're worried, do it yourself. Theyre not going to tear anything apart for 400$, just run additives/cleaners through your system. Some people run additives, some don't. If you're already using the archoil I'm sure that's plenty as long as you're regularly changing fuel filters.
