Here is a simple way to do the PCV Reroute on a LMM. Total cost is around $20. It takes 10 minutes to swap it back to stock configuration.
You will need approx 10' of 5/8" heater hose, 3/4 brass crimp tee and 6 stainless steel hose clamps. Also a 1 1/8" rubber cap, recommend a oil resistant/high temp cap (I used a barstool cap for now). Billet plugs are also available.
First start by removing the Resonator box with the "6.6" Liter on it. Then you want to cut the plastic tubing approx 3" back from the tee on both sides where it narrows so you can slide the 5/8" tubing over it. Then where the PCV line was attached to the intake remove that piece and cap it with the 1 1/8" barstool cap, hose clamp it.
Now cut a section of the hose and install it between those to pieces of plastic tubing that you cut and hose clamp it. Cut it in half and install the 3/4" tee and hose clamp it. You can reinstall the 6.6 Resonator box back over the plugged intake. On the other side install the remainder of the 5/8" hose and route it over to the drivers side and down the inside of the frame thru the holes in the supports. Recommend extending it past the cab. Zip ty it up and your'e done .
Keep the OEM PCV Tee if you need to put it back to stock form for smog etc. Easy to put back on using two 2" lengths of 5/8" hose.
Update (4/09/11) I recently installed the Billet Plugs in place of the barstool cap and rubber plug, both were still in good shape after a year. Just wanted something stronger and safer.
Photos below...
PCV KITS & PLUGS
http://www.alligatorperformance.com/part_finder_models.php?mID=19&cID=282
http://madjackdiesel.com/gm-duramax/diesel-race-parts/block-plates/pcv-re-route-kit.html
Sorry about all of the missing photos, Photobucket screwed us all by charging $400 per year to let us use them on forums!! I will fix them eventually. GrrRRrr
Photos below...
PCV KITS & PLUGS
